- This topic has 13 replies, 6 voices, and was last updated 1 year, 8 months ago by
Andrew.
October 12, 2016 at 4:46 pm #3660
KeymasterWe’ve just released the full KIT1 source code, and an upgraded server protocol that allows adding and reading additional sensors, including the highly acclaimed BME280. Read the press release here https://www.uradmonitor.com/open-source-uradmonitor-kit1/
This topic will offer assistance and guidance for compiling and modifying the uRADMonitor KIT1 firmware. Feel free to post your questions.
October 13, 2016 at 9:20 am #3664Sulley
Participantawesome stuff!
I successfully updated the firmware.
I compiled it on linux with only small changes (case sensitive fs, BME280.h vs bme280.h).I tried to hook up my bme280 breakout board (from sparkfun, https://www.sparkfun.com/products/13676 ) but had some issues and would have a couple of questions.
1. #define BME280_ADDR (0x76<<1) //0x77 default I2C address
is this correct ? Since 0x76 << 1 is not 0x772. should SDA/SLC be pulled high?
3. After some debugging, it seems that the initial i2c communication breaks on the first try here:
if (i2c_start_wait(address | I2C_WRITE)) return I2C_ERROR;
in readmem() when it tries to read the ID from 0xd0.This seems to be the first check that returns an error:
if((TWSR & 0xF8) != 0x08) return 1;
in i2c_start_wait()Any hints on what I might need to change ?
Thanks for the good work , cheers!
October 13, 2016 at 5:49 pm #3673uRADMonitor
KeymasterThe left shift is because we want the 7bit address. That is correct.
How is your BME280 connected?
“The 7-bit device address is 111011x. The 6 MSB bits are fixed. The last bit is changeable by SDO value and can be changed during operation. Connecting SDO to GND results in slave address 1110110 (0x76); connection it to VDDIO results in slave address 1110111 (0x77), which is the same as BMP280’s I2C address. The SDO pin cannot be left floating; if left floating, the I2C address will be undefined.” (BME280 datasheet)
October 13, 2016 at 9:24 pm #3674Sulley
Participanthaha, well that was some time nicely wasted
my SDO was tied to Vcc , which i knew, and i knew i needed 0x77 as address,
that comment just threw me off
thought it was already set as default and was confused with that shiftinstead of trying the obvious, i went on and started debugging i2c communication
a habit of a reverse engineer i guess…anyway, it’s working like a charm now, thanks!
October 14, 2016 at 5:18 pm #3676uRADMonitor
KeymasterThat is absolutely amazing! Congrats for being the first to manage to compile and use this new firmware (others are trying as we speak, but you were the first!)
Would you post a short tutorial on how you compiled the code and the BME280 configuration options?
The others would be so grateful!
October 15, 2016 at 11:05 pm #3678wanek
Participanthello!
@Sulley, could you please check it, that the temperature value on your display (and the device local site) it shows only integers or fractional numbers? my device shows only ints, also the local website and the graph on the server. i would like to know that it is a compilation error on my side, or there is a bug in the code. at the beginning i had some problems with floats while compiling.i see that on the attached photo there is exactly (?) 25.0 degrees. however, chances are small for that…
thanks!
June 28, 2020 at 9:14 pm #28427Outsider
ParticipantCan someone be kind enough and post a short tutorial on compiling Kit1 source code on a Windows machine?
I have Atmel Studio 7 and AVRISP MkII programmer, but I’m willing to use AVR Toolchain if that’s
what you guys used.
I have modified the source code to use my tube (STS-1, not a particularly sensitive tube but that’s what
I had on hand).There was a tutorial on this page:
https://www.uradmonitor.com/a-tutorial-how-to-compile-kit1-firmware-on-a-windows-machine/
but not anymore. Wolferl, the author, no longer has it and Radu is busy right now, so… maybe
someone saved it and would be able to post it here as a PDF or something?…
I have finished constructing the device (PCB completely redesigned to fit my enclosure), and I’m barely
waiting to compile the code and get it running!
Thank you so much!Attachments:
July 3, 2020 at 10:23 am #28430Wolferl
ModeratorHi Outsider,
I still have a machine setup for this. If you like I can compile your code for you if you like.
Too bad that the article is lost. I don’t understand why I didn’t save this locally…
Cheers
July 3, 2020 at 3:49 pm #28431Outsider
ParticipantThank you so much, Wolferl! I will send you the modified source code.
I would love to read that tutorial too, when it might resurface.
I started this project because I want to familiarize myself with both
programming in general and microcontrollers in particular, so I chose
something that interests me.July 3, 2020 at 4:11 pm #28432Wolferl
ModeratorI sent you a PM with my email addy.
November 21, 2020 at 7:44 pm #28583uRADMonitor
KeymasterLook what I was able to come up with: https://www.uradmonitor.com/a-tutorial-how-to-compile-kit1-firmware-on-a-windows-machine/
November 21, 2020 at 8:43 pm #28584Outsider
ParticipantThank you! Come what may, I have saved it now as PDF 😉
In the meantime, Wolferl helped me with the recompiling of the modified source code
(for my STS-1 tube).November 22, 2020 at 10:07 am #28585Wolferl
ModeratorGreat, thank you so much, Radu!
Saved it locally, too!
WolferlApril 25, 2024 at 1:23 pm #29811Andrew
ParticipantHello! I settled on the problem with installing this archive:
“My KIT1 script pack” with file “KIT1scripts.zip”
When you click on a link, the site does not display the desired site. Can you please send me this file for uradmonitor kit 1.1? -
